Clutch kit Patrol!
G-MAN
Full Name: A.G.HOLMES
Nickname: G-MAN
Home Language: Engels
Been thanked: 9 times
Clutch kit Patrol!
Post by G-MAN » 02 Jul 2009 19:19
Hi. A friend needs his Patrol's clutch done, :doh: where can he go( except agents) can someone point me in the right direction! :pray:
Sucks Gas and Hauls Ass!
Fanie1
Full Name: van Zyl
Nickname: Fanie
Home Town: Port Elizabeth
Current 4x4: 1998 Patrol 4500 GRX
Re: Clutch kit Patrol!
Post by Fanie1 » 02 Jul 2009 20:00
Money, money, money!!!!
In which area is he.....
The patrol has a trucks clutch......
If you speak of beauty, though alone in the dessert, you will have an audience.....
(Kalil Gibran)
1998 4500 GRX, Vd Linde Conversion (step1), ARB repl. b/bar, F/runner roof rack with awning, O/back drawers, 80l N/Luna, OME susp, Bridgestone Duelers A/T
tour de frans
Been thanked: 15 times
Post by tour de frans » 02 Jul 2009 20:06
Cape Transmission in stikland,speak to Alleric(eier).Good service and price.They did mine.0219483092
Aka: Ou Grootte
99' GU Patrol, LS1 V8 with std G/box custom convertion.Hydraulic radiator fan-motor.
The 4.2 Diesel Custom Turbo engine- retired
The 4.0 Falcon Engine- retired
Alanvs
Full Name: Alan van Schoor
Nickname: Alanvs
Home Town: Melkbosstrand, Cape Town
Current 4x4: Nissan Patrol 4500 GRX
Post by Alanvs » 03 Jul 2009 09:28
If it is Cape Town, you can also try Leon at Mazal Motors in Wynberg. 0217971550.
“One way to get the most out of life is to look upon it as an adventure”
Patrol GU 6L GRX
35's, lockers and a heavy foot.
420hp LS2 V8 conversion Happening!!!!
G-MAN
Nickname: G-MAN
Post by G-MAN » 03 Jul 2009 18:20
Thanks Guys. :thumbup:
Ross
Full Name: Ross Holland
Nickname: Ross
Home Town: Cape Town
aka "The Polar Bear"
Has thanked: 5 times
Been thanked: 7 times
Post by Ross » 06 Jul 2009 08:58
The TB42, TB45 and TD42 engined patrols all take the LUK Nissan Cabstar clutch kit, much cheaper than the stealer part.
If I remember correctly the LUK part number is either MK222 or RMK222.
Not sure what the options are for a TB48. or the 3.0TD
Hope that helps.
Ross
tour de frans
Post by tour de frans » 06 Jul 2009 13:52
The 4.2 and 4.5 clutch do differ :naughty: They are the same size and all but the 4.5 has a solid centre clutch plate and the 4.2 diesel a cushing centre.Dont mix it ,the diesel will vibrate your ears off!
Frans
Aka: Ou Grootte
Ross
Nickname: Ross
Post by Ross » 06 Jul 2009 13:58
tour de frans wrote:The 4.2 and 4.5 clutch do differ :naughty: They are the same size and all but the 4.5 has a solid centre clutch plate and the 4.2 diesel a cushing centre.Dont mix it ,the diesel will vibrate your ears off!
Frans
Okay...good to know. I was just going by what I read in the LUK catalouge a while back when I replaced mine!
Ross
G-MAN
Nickname: G-MAN
Post by G-MAN » 06 Jul 2009 19:11
Sounds like this could be a bit of a headache! :think:
tour de frans
Post by tour de frans » 06 Jul 2009 20:13
A agent clucth kit is +-R1800 for the clutch plate,R3500 for the pressure plate and release bearing R350.The rear main seal R1200 ,witch is a one piece,so a clutch job can be expensive without the labour.You can buy a aftermarket kit for R2500,the release bearing they supply is wrong,but buy the agent one.The rearmain seal is not a problem,buy a lose seal aftermarket and with very little machineing make it fit in the old housing.The seal is about R40.A after market clutch work just fine in a petrol 4.5 and just as good in a diesel 4.2 but the gearbox is a little more noizy in neutral on idle,only the diesels.Reason for that is the aftermarket clutch's centre piece springs are harder and carry the enjin noice trough the g-box.Trust me I found it the hard way after the 3rd time I pulled the box. :doh: With the wrong plate in my car the first time it sound like a truck with a cummings enjine and a fuller box that done a million miles.Driveing it in 4th gear (one to one ratio) it change the mirror ajustment,very bad.Any way my car is fixed and runnig like a mouse with socks.
Rdgs
Frans
Aka: Ou Grootte
