4.8 rough idle and stalling
graham1
Full Name: graham robertson
Nickname: graham1
Home Town: Joburg
Current 4x4: 2004 Patrol 4.8
Has thanked: 1 time
Been thanked: 18 times
Post by graham1 » 09 Apr 2018 06:57
Hi guys,
Since last friday my patrol is having a rough idle, and/or stalling at idle. Ive had a brief google of the issue but it seems theres loads of different suggestions as to what it could be.
Could it possibly be a battery on its way out? The reason I ask is a couple weeks back I saw that the battery has leaked quite alot of fluid, staining everything underneath it white. Could the bad idle be as a result of this maybe? It still starts perfectly though, no sluggish swinging etc.
Other than this, any ideas? Im getting a foot cramp having to heal and toe at the traffic lights!
Current 4x4: PATROL COLLECTION
2004 4.8 GRX "Tinkerbell"
Has thanked: 103 times
Been thanked: 73 times
Re: 4.8 rough idle and stalling
Post by hugejp » 09 Apr 2018 07:23
Mine did that a few years back & it was the MAF that was the issue.
I had no battery symptoms at all.
graham1
Nickname: graham1
Home Town: Joburg
Has thanked: 1 time
Post by graham1 » 09 Apr 2018 07:33
Ok, thanks JP.
Did you need to replace it then? Or did it just need a clean?
Has thanked: 543 times
Been thanked: 281 times
Post by Tinus lotz » 09 Apr 2018 08:15
Dont tuch it with your fingers read up but just spray with car b cleaner got a spare at home if you want to test
graham1
Nickname: graham1
Home Town: Joburg
Has thanked: 1 time
Post by graham1 » 09 Apr 2018 08:27
Ok, thanks Tinus, I'll do some reading on it now
Post by Tinus lotz » 09 Apr 2018 08:59
What about fuel pressure problems ? Check the filter under the car first?
Post by hugejp » 09 Apr 2018 09:43
:goodpost:
That filter can cause fuel starvation if its poked...
Re: my MAF, milage was around 230k & we just replaced it.
graham1
Nickname: graham1
Home Town: Joburg
Has thanked: 1 time
Post by graham1 » 09 Apr 2018 10:48
I did think about the fuel filter, but other than idling it seems to perform very well still, pulls strong etc, and no stuttering. Its just at idle.
Interesting JP, mine has just recently clocked over 230 000kms
Post by Tinus lotz » 09 Apr 2018 12:51
To change the maf takes 2 seconds come and try
graham1
Nickname: graham1
Home Town: Joburg
Has thanked: 1 time
Post by graham1 » 09 Apr 2018 16:59
Tinus sorted this in 1 second of the bonnet opening - one of the wires that goes to my MAF has a connector on it that you can interchange with the connector on the chip that’s in it, but not being used. The connector was loose so the cable wasn’t connected.
Plugged it back, crimped with the leather man, and it’s going like a rocket again!
Thanks Tinus :blonde:
Users browsing this forum: ricster and 1 guest
