4.8 Engine Sputter Rev Bounce at 2000 rpm
Current 4x4: PATROL COLLECTION
2004 4.8 GRX "Tinkerbell"
Has thanked: 103 times
Been thanked: 77 times
Re: 4.8 Engine Sputter Rev Bounce at 2000 rpm
Post by hugejp » 26 Dec 2017 13:07
karldDanneberg wrote:
26 Dec 2017 13:02
was there any change to your fuel consumption?
She definitely did have more pep on pick-up & economy did improve
Louis Nel
Full Name: Louis Nel
Nickname: Louis
Home Town: Vryheid
Been thanked: 5 times
Post by Louis Nel » 27 Dec 2017 07:47
I would not blow it with compressed air, I dono much about them but I'm pretty sure it looks the same as the 4.5's MAF.
That thing has a very thin wire in there, rather get MAF cleaner and spray with that.
You Can With a Nissan
Post by hugejp » 27 Dec 2017 08:51
Yip!
Compressed air is not the best idea.
karldDanneberg
Full Name: Karl Danneberg
Nickname: Karl
Home Town: Durbanville
Current 4x4: Patrol TB48
Has thanked: 5 times
Post by karldDanneberg » 27 Dec 2017 12:36
Havent sprayed or cleaned the MAF yet, I purchased Electronic Cleaner by Herschell for MAF cleaning tomorrow.
In the mean while, I disconnected the -ve terminal for a couple hours. It seemed as though it improved, until I was cruising slowly uphill at 2000 rpm and I switched the headlights on...the sputtering returned. This is rather suspicious, before I conclude this to be the cause, Ill let engine cool and try induce the same with headlights.
Never the less I still need to clean the MAF.
Ill keep you all posted.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Post by JoshJ » 27 Dec 2017 12:59
I wonder if this could not be earth related. A body earth that is not making good contact.
Being alive is a Blessing!!
Joshua
Louis Nel
Nickname: Louis
Home Town: Vryheid
Post by Louis Nel » 27 Dec 2017 15:46
I just spoke to a friend and he said it "Might"also be your Coolant Temp sensor. That sensor must tell the ECU how cold/hot the engine is at the given time, then the ECU will know exactly how much fuel and air to supply. He said maybe that sensor only reads 90 degrees which is operating temp, but anything before that it buggs out. Kinda makes sense cuz you said it runs fine once its at operating Temp.
Also got this from Aussie Forum on the same kind of topic.
Q.
I was wondering if anyone has had some experience with an erratic idle to the the point of stalling at times only on cold starts.After 20 secs or so it is back to normal and and no probs till next cold start.2002 gu3 4.8 ti 150k on clock petrol only.cheers..
A.
Usually its related to a coolant temp censor but they can be a bit expensive but what you can do is clean your AFM but be carefull not to wreck the little filament in it and also clean the idle speed motor and lubricate it try not to break the gasket. You can use carby cleaner and crc / wd40 to lub. Cheers
karldDanneberg
Nickname: Karl
Post by karldDanneberg » 27 Dec 2017 18:23
JoshJ wrote:
27 Dec 2017 12:59
Thanks Josh, Ill also disconnect my dual battery ctek system (in Troll fridge) and HBC solenoid (trailer) to rule out a bug in this system. As this may be the most logical earthing issue.
Beyond this...im stumped.
karldDanneberg
Nickname: Karl
Post by karldDanneberg » 27 Dec 2017 18:26
Louis Nel wrote:
27 Dec 2017 15:46
Q.
A.
Excellent thanks Louis, I never thought of this...then again my mechanical skills is rather lacking. :lol:
Ill investigate and revert. I appreciate the help.
Post by hugejp » 27 Dec 2017 22:20
Yes, please let us know where the gremlin is...
:thumbup:
Louis Nel
Nickname: Louis
Home Town: Vryheid
Post by Louis Nel » 28 Dec 2017 12:33
Right this is what my friend texted me this morning on whatsapp.
Louis dit kan n klomp goed wees, dit kan die
Water Temp sensor
Barometric pressure sensor
air temp sensor
coil of disi
MAF
throttle position senor wees
Wat ek voorstel as die ou nie diagnostics op die kar kan doen nie,
Begin by n punt, start en sien of hy die limiter het, as hy dit het plug die maf seonsor uit en kyk of daar n verskil is.
Tot hy n sensor kry wat nie n verskil maak nie.
Se vir hom om iemand met n ordentlike diagnostic te kry om net n scan te doen en dalk die actual values te kyk as die kar lop en limiter maak.
That is all I have on this. Hope it helps :)
All the best!
