Y60 orGQ 60
dapper
Junior Member
Junior Member
Full Name: Pieter van der merwe
Nickname: Dapper
Home Town: Vyeboom
Current 4x4: hilux 2.7
Home Language: afrikaans
Y60 orGQ 60
Post by dapper » 17 Feb 2010 20:45
Do you get these in a 4.5 fuel injection and what power do they make,sure i saw a model labelled like that.
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Re: Y60 orGQ 60
Post by Gerrit Loubser » 17 Feb 2010 21:08
The previous, more boxy shape Patrol has the Nissan model code Y60 (the current one is Y61). The Y60 is also known as the GQ in Australia, where they seem to assign their own codes to vehicles (the current one is known as the GU).
The Y60 was built from around 1987 and was replaced by the Y61 in late 1997, although the older model soldiered on for the military market in the East.
The Y60s that were imported to SA by Nissan SA all have either 4.2 carb fed petrol motors (engine code TB42, 125 kW @ 4200 rpm, 325 Nm @ 2800 rpm) or 4.2 naturally aspirated diesels (engine code TD42, 85 kW @ 4000 rpm, 264 Nm @ 2000 rpm).
Return to “08. Your Patrol”
Users browsing this forum: martyn and 1 guest
