Servicing a GU TD42
- davejones
- Full Name: David Jones
- Nickname: David
- Home Town: Lagos, Nigeria
- Been thanked: 5 times
Servicing a GU TD42
Gents
I would like to service my diesel, its been 12 months / 5,700km since the last service.
For now I want to change the engine oil, replace the oil filters and fuel filter. Later will be radiator/cooling system (water looking a bit dirty).
Is there a particular oil i should be using (and why), and does anyone know the correct part numbers for the filters?
David
David
An ox, but with balls !!!
- Nickname: Kosie
- Home Language: TWEETALIG
Re: Servicing a GU TD42
OIL FILTER GUD 2 X Z 292
DIESEL FILTER FRAM 4922
AIR FILTER GUD 1001
It was for my GQ td42
AIR FILTER GUD 1001
Land Rover Discovery 3 TDV6
- davejones
- Nickname: David
Thanks Koos
What is the best oil to use for the TD42?
Reading a lot on the aussie forum, not sure what is available and suitable locally?
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Dave, there are many good oils and people often tend to be fanatical followers of a particular brand.
I have had good results in my Pajero DiD with Caltex Delo 400 as well as with Mobil Delvac. By good results I mean that I have used those products over at least the last 125000 km (first Delvac, then Delo 400 for a while and then back to Delvac) and have enjoyed a smooth running, quiet motor that seams very healthy and nowhere near the end of its life at 200000 km. I know this is not super scientific. I know of many other Delo 400 followers.
- SRXy
- Full Name: Wes
- Nickname: the Knob...
- Home Town: Slaapstad
- Current 4x4: TD42T Patrol "The Wee Beasty", 373,000km's
Umm....this is a Patrol forum isn't it? - Home Language: engles
- Been thanked: 1 time
I use Caltex Delo 400 as well because it makes the engine run smoothly and pretty quietly (for a 4.2 diesel forklift motor). I've tried a few different oils and Delo seems to be the "smoothest". I change oil every 5000km's though...so probably not a very good representative sample.
There are two different lengths of oil filter for the TD42 (for both GUD and FRAM), I use the long FRAM one which has the part number PH2850. I can't remember the fuel filter part # offhand....but I can have a look if you want? Remember that you will have to prime the fuel filter once it's been replaced.
- tour de frans
- Been thanked: 21 times
Hi SRXy,the oil filter # you quote,are that the shorter one?
Tnks
Frans
Tnks
Frans
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 4 times
Ja...add another vote for Delo 400....a very good oil. If I can`t find Delo 400, then Mobil Delvac MX is also decent.
@Frans: The Fram PH2850 is the same length as a GUD Z292. I was given the shorter ones accidentally once, but I can`t recall the part number. I figure bigger is better, so didn`t use them I exchanged them for the longer ones.
Ross
aka "The Polar Bear"
- SRXy
- Full Name: Wes
Frans,tour de frans wrote:Hi SRXy,the oil filter # you quote,are that the shorter one?
Tnks
Frans
The part number I quoted is for the long ones. I feel the same as ross...I prefer the idea of a big filter (more surface area for the filter) and it's also easier to get hold of to put in and take out! I also got given the shorter one initially.
Wes
- davejones
- Nickname: David
Ended up servicing on Friday as on Thursday evening, after seeing Russ's Patrol in the snow, decided I was going to the Drakensburg.
Replaced oil and filters, used Delo 400 and GUD Z292 filters (larger than the PH2850).
Replaced diesel filter, GUD188.
I struggled like you cannot believe to the darn filters off patience was needed in abundance!!
For the diesel filter, ended up taking out the entire mechanism, secured it in a vice, and hammered through a screw driver.... worked like a charm!!
Needless to say, in 5000km if it is that difficult again; ill only have myself to blame !!
Next on the list is cooling system, geabox and diff oils - any advice on these items?
David
David
- Been thanked: 468 times
Dave.... did you ever change your diff, gearbox and transfer box oils?
If so what oils did you use.... GL 5 or GL 4etc. I ask cause I tink I should do mine !!.... I don't know when last it was done either.
